What Carbs
stempy
What Carbs
#1 PostAuthor: stempy » Tue May 28, 2013 8:40 am
Looking to see if anyone can identify these carbs
Float bowls have dome extra take of tubes ???
PUM 451
#2 PostAuthor: ADRIAN H » Tue May 28, 2013 8:48 am
If you click on the pics in link below, pics enlarge.
Z1 - Z1B = 28mm = 2 fuel lines
Z900 - Z1000 = 26mm - 2 fuel lines
Z1R = 26mm = 28mm - 1 fuel line
They look like Z900 - Z1000
http://www.z1enterprises.com/Z1CarbGuide.aspx
#3 PostAuthor: zed1015 » Tue May 28, 2013 9:48 am
The three odd float bowls are off carbs that had an accelerator pump fitted.
The forth matching bowl would have had the pump on and would have been on number two carb.
These carbs are either accel pump carbs with the pump missing or none pumper carbs with three odd bowls.
The pumper carbs will have a jet sticking up in the mouths of the carbs which i can't see from this angle.
The brass tubes on the bowls link together to feed fuel to each carb accel jet.
If these are std carbs and you have no spare std bowls then just switch the middle two bowls and connect them all up with some tube to blank them off.
#4 PostAuthor: ADRIAN H » Tue May 28, 2013 12:44 pm
Did nt notice the 3 float bowls before, they are not right.
jimmock
#5 PostAuthor: jimmock » Tue May 28, 2013 12:47 pm
Fukc me,
You Guyz know your stuff!!!
Jimmock. :wnkr
I hate people I don't like !
ted1r
post
#6 PostAuthor: ted1r » Tue May 28, 2013 6:35 pm
Z1r s run 28mm not 26mm Adrian for info.
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
Z1parR
#7 PostAuthor: Z1parR » Tue May 28, 2013 6:36 pm
Exactly as Rob said one of the bowls is a stray , this is what they should look like with the pump .
0172 . Geoff Parr
Re: post
#8 PostAuthor: ADRIAN H » Tue May 28, 2013 7:35 pm
ted1r wrote:Z1r s run 28mm not 26mm Adrian for info.
Ted
I knew that, typo .. .. Doh. I`ll get my coat. :oops:
The Z1000 Mk II - had accelerator pumps.
jphaynes669
#9 PostAuthor: jphaynes669 » Tue May 28, 2013 8:26 pm
My mk2 does not have pumper carbs, but my us spec z1000st does. This could be a mixture of the two? Hope this helps :wink:
Jeff.H
