z1r oil cooler
xsfool
z1r oil cooler
#1 PostAuthor: xsfool » Fri Jun 14, 2013 12:44 am
Hi guys, I know this topic has been done to death, but I'm addicted to ebay and couldn't help myself...
Oil cooler and fittings from the crankcase ( oil pressure sensor take off? and the other one next to it) bought.
What size hose (internal diameter) should I buy? Most seem to come with a AN rating, good old imperial measurements :shock:
Also, do I need high pressure fittings, or will a simple push on/ barb fitting be ok? with a securing clip, obviously.
#2 PostAuthor: Pigford » Fri Jun 14, 2013 6:33 am
Get the "take-offs" the if they're push fit, get decent oil hose to suit.
Don't need hi-pressure fittings - it's only 3psi :wink:
steve bowdler
#3 PostAuthor: steve bowdler » Fri Jun 14, 2013 7:35 am
Look on ebay seller torques uk very helpful and good quality pretty reasonable as well could email him info@torques.co.uk
#4 PostAuthor: zed1015 » Fri Jun 14, 2013 8:42 am
Put up a pic of the take offs for a better answer.
Most use AN6 to AN8 fittings or barbs for 8mm or 12mm bore pipe .
I make my own fittings , buy coolers with 1/2 bsp fittings and use Goodyear 12mm bore fuel/emmission hose.
Look in my projects for pics.
xsfool
#5 PostAuthor: xsfool » Fri Jun 14, 2013 4:24 pm
The fittings are tapped 1/4 NPT, I can get an adaptor to screw into that at whatever size is preferable. If AN -8 is the one to go for, I'll buy suitable hose and go with that.
cheers guys
Users browsing this forum: No registered users and 103 guests
