z900/1000 lock up spacer.
#1 PostAuthor: zed1015 » Fri Aug 23, 2013 12:42 pm
Spacer needed for the STD Z9/1000 clutch cover to allow fitment of a lock up whilst retaining the original look.
Must be a spacer not a complete top hat cover, it's for the Orient drag bike so need to retain the std cover.
Thanks.
#2 PostAuthor: Al » Fri Aug 23, 2013 5:45 pm
Have you got any scrap cases?
Could angle grind away the outer inch and then mill flat again.
I have a pair of scrap J cases but there not going to do you any good for this.
