Carb Identification
freddyz1r
Carb Identification
#1 PostAuthor: freddyz1r » Mon Oct 14, 2013 4:07 pm
Hi, I am trying to identify what these carbs are originally off. The first set are 26mm and the second set are 28mm. If anyone there thoughts please and if anyone knows an approximate value of them. Thanks in advance, Freddy. (26mm = Z1000 A1?)
28mm
#2 PostAuthor: z1bman » Mon Oct 14, 2013 5:36 pm
26mm possibly z1000a import
28 mm z1000 st / mk11 but no 3 carb has been changed + is a no 1 cylinder carb. mixture screw on no 3 carb should be on the right side not the left
#3 PostAuthor: zed1015 » Mon Oct 14, 2013 6:53 pm
26mm is 1000A
28mm is z1r /mk2 but could also be GS1000 (they had 26 or 28 and those plain alloy outer fuel gallery connectors)
#4 PostAuthor: chrisu » Mon Oct 14, 2013 6:59 pm
26mm look like 900A4.
28mm look like Z1R
freddyz1r
#5 PostAuthor: freddyz1r » Mon Oct 14, 2013 7:25 pm
Thanks for your replys gents
Chrisu , i didn,t think the 900 had an adjuster screw in the bowl.?
Are the carbs interchangeable, i.e. will these 28mm work fine on my z1r d1 ?
I cant see any reason why not. :?:
#6 PostAuthor: z1bman » Mon Oct 14, 2013 8:47 pm
shouldn't see why not
#7 PostAuthor: zed1015 » Mon Oct 14, 2013 9:35 pm
28's should be on the Z1R as std.
#8 PostAuthor: chrisu » Tue Oct 15, 2013 6:01 am
freddyz1r wrote:Thanks for your replys gents
you're right - teach me to not look at the photos properly.........
z1000puddin
#9 PostAuthor: z1000puddin » Tue Oct 15, 2013 9:54 pm
Check out Old wiredgeorges site. THE Mikuni carb GURU
Stu
http://www.wgcarbs.com/index.php/using- ... 92-z1-carb
Zed til Dead
Users browsing this forum: Bing [Bot] and 118 guests
