Engine Rebuild
Wayne1960
Engine Rebuild
#1 PostAuthor: Wayne1960 » Tue Dec 03, 2013 10:01 pm
Has anyone built their engine inside the frame so from the sump up? If so how was it?
Saves havering to lift the lump in after it's built.
Bike now finished what a joy!
Re: Engine Rebuild
#2 PostAuthor: Pigford » Tue Dec 03, 2013 10:05 pm
Wayne1960 wrote:Has anyone built their engine inside the frame so from the sump up? If so how was it?
If you're going to rebuild a motor - do it properly on a bench - then when done, lay motor on its side and lower the naked frame over it :wink:
Wayne1960
#3 PostAuthor: Wayne1960 » Tue Dec 03, 2013 10:10 pm
Yeh I've seen that and looks the better option. Just wanted to try a different approach.
Is there any reason why it won't work?
#4 PostAuthor: z1bman » Tue Dec 03, 2013 10:15 pm
you can build the bottom half of the engine including the sump but leave the generator + the cover of until the engine is in the frame
Jay1969
#5 PostAuthor: Jay1969 » Tue Dec 03, 2013 10:23 pm
I've never tried putting an engine in a Human skeleton myself :wink:
Have you dismantled your engine fully yet Wayne?
From what I've done to my KZ1000 engine so far,
dismantling it I've thoroughly enjoyed it!
Snail pace at the moment because of home duties,
but I'll get it all done with a big help from my friends :)
KeithZ1R
#6 PostAuthor: KeithZ1R » Tue Dec 03, 2013 10:36 pm
z1bman wrote:you can build the bottom half of the engine including the sump but leave the generator + the cover of until the engine is in the frame
This is the way i do all mine . Build up he bottem end minus all side covers .. Lift the frame onto the engine and secure it with the mounts sit it upright and bolt the top end end on followed by the side covers seems the easiest and logical proceedure, but somebody will tell you its the wrong way , bottom line is, do it however way you can manage that makes it easy
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#7 PostAuthor: zed1015 » Tue Dec 03, 2013 11:18 pm
I usually build them up on the bench then lay them on their side and drop the frame over but with the café racer i had to fit the bottom end first as everything is so tight the complete lump won't go it in one piece.
Nothing wrong with either method, it's the final result that counts.
Jay1969
#8 PostAuthor: Jay1969 » Tue Dec 03, 2013 11:26 pm
Great wisdom from zed1015. Thank you, you're the coolest :bow
Wayne1960
#9 PostAuthor: Wayne1960 » Tue Dec 03, 2013 11:44 pm
Ok I'm might just try to be different! Jay yes totally stripped and all with Steve Smethurst. He has just finished polishing and hope to get stuff back next week. I'll post some pics when I work out how to!
And Jay loving every minute. Just got refurbished clocks back from Al Marshall. Wow he knows his trade. They look brand new but my original clocks and mileage.
[/img]
#10 PostAuthor: Ginger Bear » Wed Dec 04, 2013 7:18 am
Bottom end + barrels for me. I find it's much easier to deal with those piston rings without a load of frame tubes in the way, then as others say, on it's side and 'frame over'. :sou
But this really should be in 'Bike help', so that's where I've moved it!
Jay1969
#11 PostAuthor: Jay1969 » Wed Dec 04, 2013 9:08 am
Wayne1960 wrote:Ok I'm might just try to be different! Jay yes totally stripped and all with Steve Smethurst. He has just finished polishing and hope to get stuff back next week. I'll post some pics when I work out how to!
[/img]
Looking forward to seeing those pics Wayne, link to a how
to post pictures to this forum here http://z1ownersclub.co.uk/forum/viewtopic.php?t=25984
Best wishes :-)
Users browsing this forum: No registered users and 180 guests
