Just gathering info
Where could one lay his hands on a set of 1170 pistons or possibly a kit to suit a Gpz 1100 a2 motor
1170 pistons and possibly the barrels
- big green bus
garyd wrote:Can you enlighten me as I'm a bit confused....(Insert witty comment here)
Is your engine based on the Z1000J?
If so I thought the J and the B1/B21100s were 17mm wrist pins and it was only the Unitrack that had 18mm Wrist pins.
As always I'm happy to be correct if I'm wrong.
Gary
Ad does say for GPZ1100 A motor.
