Can anyone help with good topic and pics for reassembling my Mikuni carbs. They are the 26mm type for KZ900 A4.
Also can anyone tell me if I can replace the the brass needle that sticks out of the base of the main body. It has snapped in half!
Carbs
Wayne , the brass choke tube will twist out easily from the main body if you grip it with pliers .
PM me your address and i'll send you a whole one tomorrow .
I may have some pics of a complete set of 26s , i've certainly got pics of 28s .
They aren't that different visually , mainly the tickover adjustment really
0172 . Geoff Parr
Thanks for trying at least I know it can be changed, I have just pulled out the old one, well what was left of it! Yes it came out easy so thanks.
I have also noticed the brass tube bit on the bottom cover has snapped off on one. I managed to pull out the bit on the other side which will know need replacing and I guess the bit lft in the body where the tube part has broken off will need drilling out.
Where can I get replacement parts?
Sent PM
Sent PM
Bike now finished what a joy!
I've bought jets from here before;
http://www.motocarb.co.uk/default.htm
I'm sure there will be varied opinions and more suggestions of part sources.
Users browsing this forum: No registered users and 120 guests
