carb again
carb again
hi just about completed putting my carbs back together. Still need to get a replacement choke tube.
Also
got a carb kit from Keyster which comes with the needle jet which is item 45 on the parts list. I don't recall this being removed when I stripped down the carbs!!
does it simply slide over the jet needle 16 before the needle jet holder is screwed back in place????
Carbs are Mikuni VM26 SS
Also
Bike now finished what a joy!
Ok I sort of understand but some of the names you are giving the parts are new to me ie emulsion tube! is this the needle jet holder?
the jet itself is brass and has a flange a 3rd of the way up the shank so which way up does it go?
sorry to be a pain but I wont to get it right.
Yes! Emulsion tube = jet holder.
The jet is stepped and the smallest diameter (like a brass tube) sits in the carb body and protrudes slightly in to the venturi (carb bore).
As z1bman points out the widest end of the jet has a slight taper on it and the needle jet holder butts up against this to keep the jet seated in the carb body.
thanks guys I'm getting the picture. I will take a look at the carbs tonight. I'm guessing this can be installed from the float chamber and no need to remove tops.
I recon the originals must be still in there. if that's the case I will have to knock them out from the top.
If anyone has any pictures I would really appreciate it.
Wayne1960 wrote:Ok thanks all for your help I have it sorted! only thing I am looking for now is the brass choke tube. if anyone has one kicking about spare ?
I may have a spare, will look at lunchtime and come back to you.
Wayne1960 wrote:Adrian
That would be very helpful
Wayne,
I have one off a set of Z1000 VM26 carbs you can have.
PM or email me your address details and I will put one the post tomorrow.
No charge.
snotie1965
Users browsing this forum: Bing [Bot] and 122 guests
