28mm carb
DaveZ1
28mm carb
#1 PostAuthor: DaveZ1 » Mon Jan 27, 2014 9:41 am
Looking for a Z1a Z1b number 4 carb body (right hand outer) just the body, dont need the float bowl or top or any linkages but anything thats out there will do so long as it can br restored.
Thanks guyz.
surreyz90075
carb body
#2 PostAuthor: surreyz90075 » Mon Feb 10, 2014 9:58 pm
Hi Dave
Did you sort out the carb body? What numbers should be on it?
I have a few 28mm carb bodies and parts.
Ken
DaveZ1
#3 PostAuthor: DaveZ1 » Mon Feb 10, 2014 10:10 pm
Cheers Ken I will post a photo of the carb body that I am after tomorrow.
But its off a Z1B or late Z1A.
Cheers Dave
DaveZ1
#4 PostAuthor: DaveZ1 » Tue Feb 11, 2014 7:34 pm
Hi Ken thanks for the offer heres the photos I have of the carb type I am after it is the right outer carb ( if you were sitting on the bike) From a Z1B.
Just the body required but I will consider anything so long as its the correct type. The numbers are pointed out and read: 217 on the left and 15 on the right side. Not sure but 51 may indicate Jan 75 I am sure someone on here will verify this but I dont know what the 217 means.
Anyway heres the pics and thanks for any help you can offer.
Cheers Dave
This is what it looks like with the bowl removed.
