Z1 engine fitting
Paul Mc
Z1 engine fitting
#1 PostAuthor: Paul Mc » Mon Feb 17, 2014 10:27 pm
I'm shortly going to fit my Z1 engine back into the frame. I haven't fitted anything else onto the frame yet. It would be just the bottom end I intend to fit the top end when it's in the frame to keep the weight down.
Does anyone have any tips to make this process any easier as I'll probably end up doing this solo. My wife would rather have a route canal than go in the garage! Although I could possibly rope a neighbour in.
Many thanks for any help.
Paul Mc
#2 PostAuthor: zed1015 » Tue Feb 18, 2014 12:05 am
The usual dodge for one man fitting is to lay the engine on it's right hand side (clutch side), lower the frame over it, drop in a couple of bolts to keep it located then stand the whole lot upright.
davejames
#3 PostAuthor: davejames » Tue Feb 18, 2014 12:27 am
I'm available if you need a hand, and I'm only up the road. Waiting for your call Paul :D :D
Paul Mc
#4 PostAuthor: Paul Mc » Tue Feb 18, 2014 9:19 am
Thanks very much guys. I'll give you a shout dave,with some beers in the fridge obviously!
Paul Mc
A1John
#5 PostAuthor: A1John » Tue Feb 18, 2014 9:29 am
I always lay the frame over the engine it makes the job easy and no scratches.[img][img]http://i1199.photobucket.com/albums/aa469/zed1a/SL380282.jpg[/img][/img]
oldtimer
#6 PostAuthor: oldtimer » Tue Feb 18, 2014 11:12 am
I fully protect the frame first so not to scratch it then do as the others do, did the last one on my own, bit of a maul but managed it. If you are just fitting the bottom end then you could manage on your own with the frame upright and lower rails protected.
davejames
#7 PostAuthor: davejames » Wed Feb 19, 2014 1:23 am
Cheers Paul :beer
Users browsing this forum: Bing [Bot] and 193 guests
