Engine Rebuild
Wayne1960
Engine Rebuild
#1 PostAuthor: Wayne1960 » Mon Mar 17, 2014 1:17 pm
Ok Engine going back together. should i coat all the parts with oil as i am installing them?
If yes, does it have to be engine oil or can i use a spray? trying to keep it as clean as possible!!!
Bike now finished what a joy!
#2 PostAuthor: chrisu » Mon Mar 17, 2014 1:47 pm
engine oil or assembly lube while building..
i normally use an oil car with bike 10/40 in it.
fill sump to correct level..
turn over (no spark) until oil light goes out.
#3 PostAuthor: zed1015 » Mon Mar 17, 2014 1:51 pm
Ideally you should use the same type/make oil that is going in the engine.
Just a squirt in the bearings will do.
Don't oil the bores though as this will prevent ring bedding if they are new.
I use Graphogen assembly compound on the piston skirts and on the cam shell etc but oil will do the trick.
Wayne1960
#4 PostAuthor: Wayne1960 » Mon Mar 17, 2014 2:41 pm
What is the recommended oil of choice.
Users browsing this forum: No registered users and 134 guests
