Think I just messed up! Put all the valves back into the cylinder last night. Order of install was
Put new oil seal on to valve guide
Push valve into place
Drop the washer on top
Then the 2 springs
Then the washer
Compress
Split collars
I'm now thinking the first washer should have gone on before the oil seal
Was I right in the first place!!!!
Valves
Wayne, regret to say you have done it wrong way round.
After checking that the valve is able to come within range of the shims. ****
Insert lower washer over valve guide.
Push valve in place.
Carefully put oil seal on valve and check that it's spring circlip clicks into place.
Add both springs.
Add top washer and compress with valve compressor.
Slip in split collets and release valve compressor.
RegardZ
Add both springs.
RegardZ
Wayne, if you have a close look at a valve guide, you will find a groove that holds the valve seal in place. Depending on the type of seals you are using, check that the small circlip/ spring-clip has not become separated from the seal as they are installed or retrieved.
RegardZ.
RegardZ.
Users browsing this forum: No registered users and 217 guests
