Dyna S - Z1B to GPz1100B1
Big Fluff
#1 PostAuthor: Big Fluff » Fri Apr 04, 2014 5:26 pm
I have fitted the old Dyna-S ignition system from the Saxon onto the GPz1100B1 engine in my ELR.
I can't get the timing anywhere near (well about 5 degrees from where I'd like it) and I'm pretty sure it's the rotor that's different.
The mechanical advance unit is the original GPz1100B1 item with the Dyna-S Z1B rotor fitted.
I have two questions:
1). What number rotor should I fit (3, 3A etc)
2). Can I simply elongate the the three holes in the backplate to bring the timing in?
Thanks, Will
#2 PostAuthor: Pigford » Fri Apr 04, 2014 5:48 pm
Will, just s t r e t c h the bleedin' holes lad :wink:
#3 PostAuthor: z1bman » Fri Apr 04, 2014 7:09 pm
as long as the timing is correct at full advance i wouldn't worry about it
wilsonsjw11
#4 PostAuthor: wilsonsjw11 » Fri Apr 04, 2014 7:09 pm
Will
3A is for 72/73 Z1 engine.
Ditto what Pigford says about elongating the module back plate holes.
Regards
Steve
PAULJAC47
#5 PostAuthor: PAULJAC47 » Fri Apr 04, 2014 7:23 pm
Will i had this same problem and looked at the rotors and elongating the slots,till i stripped down and found the split pin dowl in the end of the shaft had bent and was causing the error in the timing,worth a look mate,,Cheers Paul J
Big Fluff
#6 PostAuthor: Big Fluff » Fri Apr 04, 2014 7:27 pm
Cheers guys, pin on the end of the crank is fine. Will elongate the holes and set at full advance.
#7 PostAuthor: Pigford » Fri Apr 04, 2014 7:37 pm
Big Fluff wrote:Cheers guys, pin on the end of the crank is fine. Will elongate the holes and set at full advance.
Even if the advance is a bit out (too slow or fast}, I've never noticed much difference on my Z1000 - and remember to hold the advancer fully open when setting :wink:
Garn 1
#8 PostAuthor: Garn 1 » Fri Apr 04, 2014 11:33 pm
Big Fluff, I have never tried this, however, somewhere in a DynaS previous posting, someone suggested you reverse the plates so that the modules are screwed from the other side and there is room for adjusting to full advance, without elongating holes. Probably worth a try! It just changes the geometry of the hole positions.
RegardZ.
Big Fluff
#9 PostAuthor: Big Fluff » Sat Apr 05, 2014 12:30 pm
Garn 1 wrote:Big Fluff, I have never tried this, however, somewhere in a DynaS previous posting, someone suggested you reverse the plates so that the modules are screwed from the other side and there is room for adjusting to full advance, without elongating holes. Probably worth a try! It just changes the geometry of the hole positions.
RegardZ.
I'll give that a go this afternoon :up
#10 PostAuthor: Pigford » Sat Apr 05, 2014 3:52 pm
RegardZ.
That'll be good info if it works :wink:
Big Fluff
#11 PostAuthor: Big Fluff » Sat Apr 05, 2014 4:19 pm
Update
The adjustment holes are symmetrical so in the end I had to elongate them.
The ignition timing, both fully advanced and static are now bang on.
However it still runs like a complete bag of shit :evil:
Hence the HELP thread http://z1ownersclub.co.uk/forum/viewtop ... 486#257486
Cheers, Will
Users browsing this forum: No registered users and 219 guests
