Cylinder Studs
Wayne1960
Cylinder Studs
#1 PostAuthor: Wayne1960 » Tue Apr 08, 2014 6:37 am
What's the best way to install the cylinder studs and torque them down? Shoul I use on of the chrome nuts or a pair of nuts locked off? Doesn't look like enough room for 2 nuts.
Should I use loctite on the threads?
Bike now finished what a joy!
#2 PostAuthor: zed1015 » Tue Apr 08, 2014 9:00 am
Use a spare cylinder head nut with a 6mm or 8mm ball bearing inside sat on top of the stud.
You will be able to torque the stud down and the nut will release easily.
This is how the factory tool works.
If you look at the top of the original studs you will see a small dimple from when they were done originally.
Use thread lock at the crankcase end.
Wayne1960
#3 PostAuthor: Wayne1960 » Tue Apr 08, 2014 9:08 am
Fantastic i looked through the manual but struggling to find the torque settings for these, can you help?
#4 PostAuthor: zed1015 » Tue Apr 08, 2014 9:54 am
The studs don't need a lot of torque.
On STD studs apply Loctite and screw them in until the step above the thread bottoms out on the case and then torque to only 10 to 12 ft/lb.
With HD studs with no step they need to be screwed in with Loctite until they sit at the correct height (take height measurements from original studs) and left to set.
If these are screwed in too far they will pop out the casting at the bottom of the hole.
Users browsing this forum: No registered users and 214 guests
