Tappet Buckets
Tappet Buckets
Just put all the valves back in and dropped the tappet buckets on and all fit great except one which is very tight. The socket is all clean and the bucket looks ok. Any reason why and if it's a proble?
Bike now finished what a joy!
wilsonsjw11
If there has been any weld repairs in that area it can distort the bucket bore.
If this is the case or it isn't a rogue bucket then wipe the bore with some engineers blue or permanent marker and push the bucket in.
You will need to remove the valve first so you can access the under side to tap it out again.
You should be able to see any high spots and then carefully ease them down with some 1000 /1200 grade wet'n'dry.
Repeat the process until the bucket slides as easily as the others.
Users browsing this forum: No registered users and 141 guests
