Help
kennytcr
Help
#1 PostAuthor: kennytcr » Sun Apr 13, 2014 8:33 pm
Drained the oil for the first time today on my z1000 a1 and this came out on the plug?
Only thing I could think of was upper chain tensioner, took cam cover of and all is ok.
Anywhere else it could of come from?
#2 PostAuthor: zed1015 » Sun Apr 13, 2014 8:38 pm
Yes! it's off the upper camchain idler.
Luckily no harm done so un bolt the idler and stick it back where it belongs.
jimmock
#3 PostAuthor: jimmock » Sun Apr 13, 2014 10:50 pm
FOOKIN' 'ELL, THAT DOES LOOK SCARY !!!
Jimmock. :wnkr
I hate people I don't like !
#4 PostAuthor: zed1015 » Mon Apr 14, 2014 8:03 am
It hasn't come adrift while running, that's impossible as it sits under or over the top idler damper rubbers and is bolted down.
There are four of them ,2 above and 2 below.
Someone has dropped it down the camchain tunnel when removing or fitting the top idler when doing the cams etc.
kennytcr
#5 PostAuthor: kennytcr » Mon Apr 14, 2014 7:41 pm
ok
thanks for the reply, was a bit worried a couple of bolts might be wandering around but all looks ok up top.
