Cylinder studs
DaveZ1
Cylinder studs
#1 PostAuthor: DaveZ1 » Tue Apr 15, 2014 6:56 pm
Hi Guyz, does anyone have two short cylinder studs M10 x 158. To replace those damaged during removal on my Z1B. Anything usable will be ok, can replate if not too pitted/corroded
Thanks Dave
Yellow
#2 PostAuthor: Yellow » Tue Apr 15, 2014 6:59 pm
Are they same size as A4 ones.
If so I have some. Will pull then out tomorrow (Wed).
#3 PostAuthor: z1bman » Tue Apr 15, 2014 7:04 pm
part no 92004-1040 £6 each in stock at cradley
DaveZ1
#4 PostAuthor: DaveZ1 » Tue Apr 15, 2014 7:20 pm
Part number changed from 92004-047 to 92004-1002 for the A4 whats the difference?
Any contact details for Cradley Z1bman?
Yellow, If they are the same I will have them matey,
Cheers Dave
#5 PostAuthor: z1bman » Tue Apr 15, 2014 7:28 pm
part no 92004- 1002 i a 10mm x 190 stud ? 92004- 1040 is a 10mm x158 stud + they are the same as a z900 a4
if you need to contact cradley 01384 633 455
DaveZ1
#6 PostAuthor: DaveZ1 » Tue Apr 15, 2014 7:40 pm
Cheers Z1bman. Using Zpower parts book for part numbers had issues with these numbers being wrong before.
How do you know cradley have them in stock? Tried the web site and the part number search not showing anything.
Will call them tomorrow though.
Thanks Dave
#7 PostAuthor: z1bman » Tue Apr 15, 2014 7:52 pm
DaveZ1
#8 PostAuthor: DaveZ1 » Tue Apr 15, 2014 8:14 pm
Cheers Z1bman, 2 studs now ordered.
Yellow
#9 PostAuthor: Yellow » Wed Apr 16, 2014 9:58 am
Have them Dave,
PM your address and I'll send them.
foc.
DaveZ1
#10 PostAuthor: DaveZ1 » Sat Apr 19, 2014 10:57 am
z1bman wrote:part no 92004- 1002 i a 10mm x 190 stud ? 92004- 1040 is a 10mm x158 stud + they are the same as a z900 a4
Just recieved the studs from Cradley. Unfortunately that part Number stud length is actually more like 180mm total.
I think the 158mm length quoted on the parts list and on the discription refers to the length of the stud above the crankcase after it is screwed in.
#11 PostAuthor: z1bman » Sat Apr 19, 2014 12:36 pm
the stud length is measured from end to end I would say it is a packing error from the factory as it does say on the packaging it is 10 x 158mm. cradley have all the other studs in stock if you return the studd with your original they will match it up
Yellow
#12 PostAuthor: Yellow » Sat Apr 19, 2014 5:47 pm
2x 158's on the way. might need a clean up...
DaveZ1
#13 PostAuthor: DaveZ1 » Sun Apr 20, 2014 2:39 pm
Cheers Yellow you're a star!
