eng nos dodgy or not
baz
#1 PostAuthor: baz » Mon May 05, 2014 1:36 pm
just noticed this morn that the z1b eng that i was shifting about in the garage (again) has no raised lip were the numbers are stamped, the stamping looks right enough though :??
any body seen this before :?:
#2 PostAuthor: zed1015 » Mon May 05, 2014 1:50 pm
Early engines have no lip.
mick znone
#3 PostAuthor: mick znone » Mon May 05, 2014 1:51 pm
didnt the lip appear somewhere early in the z1a range?
baz
#4 PostAuthor: baz » Mon May 05, 2014 2:04 pm
mick z1a wrote:didnt the lip appear somewhere early in the z1a range?
hi mick, i thought that, zed 1015 is right it was the early engs, just thought ide ask the question :)
#5 PostAuthor: zed1015 » Mon May 05, 2014 2:13 pm
A pic would help.
The early number pads with no lip were shorter in length than the later ones.
baz
#6 PostAuthor: baz » Mon May 05, 2014 4:30 pm
zed1015 wrote:A pic would help.
cheers zed 1015 but i must have had to much juice this weekend, it is a z1a eng, the z1b eng is still in bits in a box :oops:
malmojoe
#7 PostAuthor: malmojoe » Mon May 05, 2014 6:29 pm
I think as Mick says, early Z1A engines were also without the lip, I think Garn did a bit of research into it so he could tell you more, but I have one around 27000 with no lip.
jimmock
#8 PostAuthor: jimmock » Tue May 06, 2014 3:38 pm
Z1 motors had a shorter "pad" for the stamping.
Jimmock. :wnkr
I hate people I don't like !
Garn 1
#9 PostAuthor: Garn 1 » Thu May 08, 2014 3:59 pm
Bas, as Malmojoe & Jimmock have mentioned the Z1's & early Z1A's were without lip and only had a shorter pad [65mm long].
I think, to prevent theft, and over-stamping about #27700 Kawasaki tried this...
extending the pad to 80mm snd giving the overall surface of the pad a lip.
Also, for a short period a checkered surface. The checkered surface must not have been successful as, I think, certain number stampings interfered with the surface and caused pieced of alloy to fall out!
I have found this only went for a few units [approx 400 to 1000 units], after which it changed to the original large font then to the last font which is smaller and slightly italic. It also gained an extra digit along the way. I have seen anomalies around this # 27700 sequence, however, as they were so good, I had to accept them or embarrass the owner.
To my knowledge, the Z1B had the 80mm pad with lip and had the six digit small slightly italic font
RegardZ.
baz
#10 PostAuthor: baz » Thu May 08, 2014 5:44 pm
cheers garn1
your spot on there pal :D
Users browsing this forum: No registered users and 179 guests
