Z900 A4/A5 engine mounting bolts thread and pitch
Gavin
#1 PostAuthor: Gavin » Sat May 24, 2014 11:28 pm
The bolts I am referring to are the two M12 lower engine mounts that uses the Steel "segments " instead of normal nuts.
The threads on one of them are in very poor condition , I want to change them but I have no idea what the thread details are apart from metric fine.
Can anyone help?
Z1000 MK2
Z1300 DFI
sanderz
#2 PostAuthor: sanderz » Mon May 26, 2014 4:27 pm
I make it M12 x 1.25 pitch - that's taken from my Z1B and using thread gauges and is 70mm long so take it there is a difference between model numbers.
Zpower only list 1 size replacement bolt for the A4 at M12 x 55 long
https://www.z-power.co.uk/merchantmanag ... cts_id=834
Hope that's of some use.
Wots up DOHC
sanderz
#3 PostAuthor: sanderz » Mon May 26, 2014 4:31 pm
Just in case its the 'pear shape' nuts as well have a browse on there listings
https://www.z-power.co.uk/merchantmanag ... _20&page=7
Wots up DOHC
#4 PostAuthor: zed1015 » Mon May 26, 2014 8:48 pm
I have an m12 x1.25 die that I use to make those bolts.
If you don't get sorted go down the Bapps etc and buy two course pitch stainless m12 bolts with long plain shanks and i'll make you a couple that fit.
They will have 19mm heads though.
jimmock
#5 PostAuthor: jimmock » Tue May 27, 2014 12:34 am
Yes, metric "super fine" 1.25 pitch.
Metric fine on 12mm is a 1.5 pitch.
Like Rob says, 17mm hex instead of a "standard" 19mm.
I too use a die of 1.25 pitch.
Jimmock. :wnkr
I hate people I don't like !
jimmock
#6 PostAuthor: jimmock » Tue May 27, 2014 12:45 am
After reading this thread again.
I'm almost certain that the two bolts in question are DIFFERENT lengths.
Jimmock. :wnkr
KeithZ1R
#7 PostAuthor: KeithZ1R » Tue May 27, 2014 8:14 am
jimmock wrote:After reading this thread again.
and you would be correct :D
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
jimmock
#8 PostAuthor: jimmock » Tue May 27, 2014 8:27 pm
Well thank you, sir.
Jimmock. :wnkr
freddyz1r
#9 PostAuthor: freddyz1r » Wed May 28, 2014 2:25 pm
I knew you would be one day Jimmock :lol:
Gavin
#10 PostAuthor: Gavin » Fri May 30, 2014 10:31 am
Cheers for the info guys
Thanks for the offer Rob
Z1000 MK2
Z1300 DFI
Users browsing this forum: No registered users and 165 guests
