630 to 530 conversion
PAULJAC47
#1 PostAuthor: PAULJAC47 » Tue Jun 10, 2014 7:47 pm
Guyz anyone know a source in the Uk for kits to convert 630 to 530 chains(Suzuki Gs1000)??
#2 PostAuthor: ADRIAN H » Tue Jun 10, 2014 9:10 pm
Z1 enterprises list (I know its not UK - but does give you the sprocket references).
http://www.z1enterprises.com/ListItems. ... 1309010000
#3 PostAuthor: zed1015 » Tue Jun 10, 2014 11:59 pm
You need a JTR816 rear sprocket. List of models in this link.
http://www.jtsprockets.com/catalogue/sprocket/JTR816
Then you need a JTF513 front sprocket.
Probably the 18 tooth of a 1250 bandit would be best.
The go buy something like a 120 link chain and chop off what you don't need.
snotie1965
#4 PostAuthor: snotie1965 » Wed Jun 11, 2014 8:37 am
Debben performance do all the kits ,i just done my uni-trak , Talon rear, sprocket gold ,and top of the range DID also gold ,bike feels loads smoother and gear change has got better ,more precise . :D cost a bit more than a standard set up ,but i think most big bikes run 530 now ?
PAULJAC47
#5 PostAuthor: PAULJAC47 » Wed Jun 11, 2014 3:16 pm
Ta Lads
Garn 1
#6 PostAuthor: Garn 1 » Mon Jun 16, 2014 1:15 am
Sorry for the lateness of my reply.
I wanted to mention about the locking tab-washer. Not sure what they have on the Suzuki, however every 530 front sprocket I've purchased has two 6mm screw holes at a different PCD than the usual small tab-hole.
I usually make up a tab washer as per pic.
I used to make them out of sheet stainless until I stuffed my hole saw!
RegardZ.
garyd
#7 PostAuthor: garyd » Mon Jun 16, 2014 8:49 pm
"until I stuffed my hole saw"
Dirty sod...no wonder it ran away
