Need advice on head repair
oldzed
#1 PostAuthor: oldzed » Mon Jun 30, 2014 10:57 pm
Hi all
During my run back from blackpool I have discovered that I have a problem with the head on my z1000ST.
I had fitted a set of Inserts into plug holes 1 and 4 a few years ago.
No 1 is now leaking compression and feels like it will strip if I try to retighten it. I had used a locking compound in it at the time.
Need a recommendation for someone who could Weld up the plug holes and retap them.
I know I could change the head, and that may be an option, but all the shims are in the 280 range so I would like to save the head if possible
Regards
Craig
member number 0664
Who can catch a Kawasaki?
A police helicopter
#2 PostAuthor: zed1015 » Mon Jun 30, 2014 11:11 pm
Are they helicoils or the solid timesert type ?
Oh! just re-read your post and they must be the solid type if fitted with Loctite.
You could take them out and have them re-threaded to take Bigserts .
oldzed
#3 PostAuthor: oldzed » Tue Jul 01, 2014 1:51 pm
Thanks Rob will look into getting a kit.
member number 0664
A police helicopter
Users browsing this forum: No registered users and 154 guests
