Maximum safe size for boring out 903cc. barrels
Lee McEvoy
#1 PostAuthor: Lee McEvoy » Tue Jul 01, 2014 6:10 pm
Thinking of putting a few more cc's but want to keep it looking stock 903 on the outside? What s the maximum safe size to go for and is high compression worth it as well? Thanks :)
#2 PostAuthor: zed1015 » Tue Jul 01, 2014 6:13 pm
You can go to 1045cc ( 71mm ) but it leaves the liners a little thin the same as pushing the 1015cc barrels to 1105.
1015cc (70mm) is the max I go to and a Wiseco 10.25-1 piston kit will do the job nicely.
Lee McEvoy
#3 PostAuthor: Lee McEvoy » Tue Jul 01, 2014 6:25 pm
Out of curiosity, can the thin liners if I took it out to 1045 be managed? Or is it just not worth it. My aim is for an every day rideable bike?
zpower
#4 PostAuthor: zpower » Tue Jul 01, 2014 8:10 pm
You could also buy a big bore kit with sleeves and pistons.
1170, 1197 :D
** Special rates for the Z1OC forum members **
Website design, hosting / domain names.
Computer and Laptop repairs.
#5 PostAuthor: Pigford » Tue Jul 01, 2014 8:19 pm
zpower wrote:You could also buy a big bore kit with sleeves and pistons.
1170, 1197 :D
The norm for that route is a 1260 - but they're trouble :lol:
#6 PostAuthor: zed1015 » Tue Jul 01, 2014 8:21 pm
Lee McEvoy wrote:Out of curiosity, can the thin liners if I took it out to 1045 be managed? Or is it just not worth it. My aim is for an every day rideable bike?
Wouldn't bother myself, there's no real power advantage to be had for an extra 30cc.
Also there's a good risk of the liner spigot (the bit that protrudes below the barrel casting) cracking as that portion is thinner than the rest of the liner and if the borer goes even slightly off centre it can get wafer thin.
zpower
#7 PostAuthor: zpower » Tue Jul 01, 2014 10:29 pm
1260 = thin liners allowing the sleeves to warp, crack etc...
1170 or 1197 kits leave more metal.
My 1197 liners are 2.5mm thick and standard 1015 liners are 2.8mm.
Lee McEvoy
#8 PostAuthor: Lee McEvoy » Wed Jul 02, 2014 5:28 pm
Sorry for ignorance, but can those big bore and sleeves go into a set of 903 barrels? Am I not then into having to alter cases as well? :oops:
neilbarrett
#9 PostAuthor: neilbarrett » Wed Jul 02, 2014 6:47 pm
id go for a 998cc kit ,the old f1 limit,
#10 PostAuthor: ADRIAN H » Wed Jul 02, 2014 7:01 pm
Lee McEvoy wrote:Sorry for ignorance, but can those big bore and sleeves go into a set of 903 barrels? Am I not then into having to alter cases as well? :oops:
Big bore kits complete with liners, would mean the crankcases would have to be machined out - to allow for the extra diameter of the liners. Talk to ray at Debben Performance in Ringwood Hants, (as he is relatively local to you) - for more info.
jimmock
#11 PostAuthor: jimmock » Wed Jul 02, 2014 7:23 pm
This is the kinda thread that makes me want to go and thrash myself into a coma!!!
Jimmock. :wnkr
I hate people I don't like !
#12 PostAuthor: ADRIAN H » Wed Jul 02, 2014 7:29 pm
jimmock wrote:This is the kinda thread that makes me want to go and thrash myself into a coma!!!
Go for it mate. :sta
#13 PostAuthor: zed1015 » Wed Jul 02, 2014 8:20 pm
Why has a simple straight forward re-bore question turned into a full on engine strip ???
Just bore it out to 70mm if you want a nice quick motor with no hassles.
You will feel the difference with a set of 10.25 comp Wiseco's and up a size or three on the main jet.
Anything involving bigger liners (even 1015 liners in some cases) will required the crankcase mouths opening up.
zpower
#14 PostAuthor: zpower » Thu Jul 03, 2014 12:19 am
Sorry guys it's my fault this thread has delved into the intricacies of installing a big bore kit :(
It was just a suggestion :lol: :dead
Lee McEvoy
#15 PostAuthor: Lee McEvoy » Thu Jul 03, 2014 9:34 pm
Gents thanks to every one for exposing all the possibilities to increase the capacity. Really want to keep it looking as stock as poss so going to look at the costs of the 1015 option with the higher compression pistons. Suppose I had better start saving! :P
Users browsing this forum: Stugill and 62 guests
