Dyna S
wilsonsjw11
Dyna S
Just fitted Dyna S to my 73 Z1 and cannot get it to fire,on the F mark on both 1+4 and 2+3 I have slotted the back plate to the point if I go any further it would block the points cover fixing screws.The magnet is correct for an early advancer marked 3A and a NOS early advancer is fitted.The modules are right at the end of their adjustment limits.The closest I can get it is to fire on the T mark.
Regards
Steve
Regards
Steve
Try fitting the modules to the rear of the plate sometimes you can get away with that trick,there is a small amount of adjustment on the modules ...
wilsonsjw11
Is the rotor the right way on the advancer? Their is a small magnet on one side that most face left when the 1- 4 side of the advancer is pointing up. Also make sure the rotor is properly engaged.
Static timing should be done with the rotor held fully clockwise(advanced) so that the timing light comes on when the right hand 1-4 mark is in line with the crankcase mark.
Hope this makes sense.
wilsonsjw11
wilsonsjw11
wilsonsjw11
