Will these fit
RUDDY
Will these fit
#1 PostAuthor: RUDDY » Fri Nov 07, 2014 6:54 am
Found these listed for a Zephyr, they appear to be £300 cheaper than Ohlins listed for a 1000R, so what's likely to be the difference, would they even fit a 1000R ?
Cheers, Paul
85 Z1100R-1
london calling
#2 PostAuthor: london calling » Fri Nov 07, 2014 7:01 am
Can't imagine they'd be far away,just slightly shorter at 347mm instead of 350mm.
The Zephyr 1100 is probably a similar weight to the 1000R.
What's the damage on these Paul ??
Jack
RUDDY
#3 PostAuthor: RUDDY » Fri Nov 07, 2014 7:07 am
The Zephyr ones are roughly £660 all in including delivery , I was quoted £982 + vat from Harris yesterday for Z1000R Ohlins
So actually these are about £530 cheaper !!
Paul
85 Z1100R-1
#4 PostAuthor: Ginger Bear » Fri Nov 07, 2014 7:40 am
The Ohlins pictured above appear to have no rebound or compression adjustment.
Unlike these that have a knurled adjuster below the spring & another on top of the reservoir.
RUDDY
#5 PostAuthor: RUDDY » Fri Nov 07, 2014 8:01 am
The Zephyr ones look narrower, 36mm piston, so would maybe allow fitment without butchering the chain guard ?
I see what you mean about certain things not on the cheaper option, well spotted Gingerbear.
Do people actually fiddle with knobs ....
85 Z1100R-1
jimmock
#6 PostAuthor: jimmock » Fri Nov 07, 2014 8:02 am
"You only get what you pay for".
Cheaper aint always best??
Jimmock. :wnkr
I hate people I don't like !
RUDDY
#7 PostAuthor: RUDDY » Fri Nov 07, 2014 8:08 am
Agree, but as another option there's Gazi shocks, these get a good report on ZRX forums, comparable to Ohlins some reckon for about £560, however they are spec'd for ZRX so longer and wider, means modifying chain guard.
85 Z1100R-1
ruffle
#8 PostAuthor: ruffle » Fri Nov 07, 2014 8:42 am
Those 'cheap' Ohlins look like the ones fitted to some Yamahaha's (XJ?) as OEM when they owned 50% of the company. No damping adjusters and they do come up on Fleabay quite often.
london calling
#9 PostAuthor: london calling » Fri Nov 07, 2014 8:48 am
Jack
Is Vic There
#10 PostAuthor: Is Vic There » Fri Nov 07, 2014 10:19 am
I have them fitted on my Z1000R, they look good but can quite honestly say that I don't ride the bike that hard that I'd feel the benefits, would swop them for some original shocks!
markz9
rear shocks
#11 PostAuthor: markz9 » Fri Nov 07, 2014 12:18 pm
I would give Maxton a shout, the pair i have on my race bike are stunning and bespoke to you and your bike also brand new, the harris price dosent include any alterations either ie stiffer springs etc
