Aeroquip front sprocket nut torqe
Guyz just fitted new 530 chain conversion to Z thou,supplied with Aeroquip front nut,have read Debbens torque these to 75 ft Lb,s as there is no locktab what are other opinions on this?...PaulJ
- Ginger Bear
First time i have used one of these nuts Steve, i take it its a fit once item due to theb triangular pressings on the outer?
- Ginger Bear
Sounds like the sort of nuts used on aircraft. The triangular pressing on the top of the nut slightly deform the thread, making it tight when the nut is fully threaded onto it's mating bolt/stud.
Just follow the fitting instructions, but if it really bothers you, you could apply a little low strength Loctite, but really there shouldn't be any need for this.
- ade woollams
don't the sprocket nuts on the gpz 1100 use a similar method
snotie1965
Reckon these are used in Aircraft!,nipped it up to 75ft ibs seems much better to me than the tab washers, so do Debbens! dont fancy taking it off though
- ade woollams
that's the same shape as the one they gave me at cradley which they said fitted the gpz shaft
