KZ1000 Compression PSI
Farmer
#1 PostAuthor: Farmer » Tue Jan 13, 2015 10:51 pm
I`ve checked the compression and they are all just on or just over 140 psi, so I`m assuming there ok. could someone tell me what it should be please ?. :)
#2 PostAuthor: Al » Tue Jan 13, 2015 11:06 pm
140 PSI is 9.5 to one.
Standard compression ratio for that bike is 9.2 : 1
Z1parR
#3 PostAuthor: Z1parR » Tue Jan 13, 2015 11:06 pm
Should be between 128psi and 156psi , yours seem healthy .
0172 . Geoff Parr
#4 PostAuthor: zed1015 » Wed Jan 14, 2015 8:10 am
You are good with 140psi.
More importantly is that the readings have no more than around a 15psi difference between the highest and the lowest as this could indicate abnormal wear or issues with valve seating etc.
jimmock
#5 PostAuthor: jimmock » Wed Jan 14, 2015 8:12 am
That is the kind of answers I just love.
Jimmock. :wnkr
I hate people I don't like !
Farmer
#6 PostAuthor: Farmer » Wed Jan 14, 2015 7:30 pm
zed1015 wrote:You are good with 140psi.
They were all between 140 and 145 psi, so should be ok then, thanks for all the replies :)
