Lockheed
stempy
Lockheed
#1 PostAuthor: stempy » Sun Feb 01, 2015 8:02 pm
Wanted Lockheed brake calipers or may consider other to upgrade brakes yo suit z1000 (Front and rear)
PUM 451
#2 PostAuthor: ADRIAN H » Sun Feb 01, 2015 8:13 pm
I think the modern equivalent of Lockhead calipers are AP racing calipers ref CP2696. Andover Norton cheapest stockist in UK.
Robw
#3 PostAuthor: Robw » Sun Feb 01, 2015 9:36 pm
I have them fitted to both my ELR and endurance racer, best brakes I have ever use, no fade around tracks
Rob
big green bus
#4 PostAuthor: big green bus » Sun Feb 01, 2015 9:47 pm
best brakes ever :D
martinz1000r
#5 PostAuthor: martinz1000r » Mon Feb 02, 2015 10:32 am
I have a pair of AP Lockheed calipers. CR2696 twin piston. Came with my Harris in a big box of bits. Can't guarantee seals etc but pistons do seem to move. You will need pads/pins. They are AP Lockheed branded so are old (current ones only have AP in the casting).
£100 the pair posted if interested. There is also a matching master cylinder but it has no break lever. Again old as full metal casting including fluid reservoir and cap. New ones are plastic. Can add this for extra £50. Levers, pads etc available from Dennis Trollope Racing in Bristol.
KWACKERZ1
#6 PostAuthor: KWACKERZ1 » Mon Feb 02, 2015 1:26 pm
Martin, if Stempy does not have them can I HAVE FIRST SHOUT please
ruffle
#7 PostAuthor: ruffle » Mon Feb 02, 2015 1:34 pm
Poo :( beaten by a couple of minutes.
Can I have second first shout?
stempy
#8 PostAuthor: stempy » Mon Feb 02, 2015 2:15 pm
Martin PM Sent
PUM 451
martinz1000r
#9 PostAuthor: martinz1000r » Mon Feb 02, 2015 4:08 pm
Folks, someone else was even quicker off the mark with a PM! Rick obviously gets first shout but here are the offending items. What you see is what you get. Not tried, tested or fitted. I suspect OEM on a Norton or Triumph? Please advise:
martinz1000r
#10 PostAuthor: martinz1000r » Mon Feb 02, 2015 6:41 pm
Deal done to Mr Stemp!
#11 PostAuthor: ADRIAN H » Mon Feb 02, 2015 8:10 pm
Aaaargh B******. I should have put a wanted post up.
:lol: :lol:
