Which valve guides?
sprint
Which valve guides?
#1 PostAuthor: sprint » Sun Feb 08, 2015 6:18 pm
The valve guides on my A4 need replacing. It still has the original phosphor bronze guides, which were prone to premature wear, question is which are the best replacements?
Are the APE guides OK? Being phosphor Bronze themself are they any better than the original ones or is it better to replace them with cast iron ones, as Kawasaki later changed to?
Don't plan to use genuine Kawasaki ones as they are too expensive.
Original valves and springs are all still OK.
Z1parR
#2 PostAuthor: Z1parR » Sun Feb 08, 2015 6:30 pm
I did a head last summer and bought these fron zpower .
Don't forget to buy the circlips too . :oops:
https://www.z-power.co.uk/merchantmanag ... ts_id=1307
0172 . Geoff Parr
sprint
#3 PostAuthor: sprint » Sun Feb 08, 2015 7:11 pm
Thanks for the reply.
These look to be the cast iron versions? Circlips look to be included.
Did you remove the old guides and fit the new ones yourself? If so did you drift the new ones in or have them pressed in?
Did you then have to ream the guides and have the seats cut or were you able to just grind the valves in?
Anybody used the APE ones?
Z1parR
#4 PostAuthor: Z1parR » Sun Feb 08, 2015 7:50 pm
Those in the link i bought from zpower , they didn't come with circlips as i found out .
After drilling through the old guides with progressivley larger drill bits .
With plenty of heat from a torch i knocked the guides out with an ally drift .
Then knocked the cooled new guides in immediately after .
You will have to run a 7mm reamer through the guide before lightly re cutting the seats .
If you manage to align the new guide with the existing seat then it will be a fluke .
Then just lap the valves to the seats as per normal clean up .
0172 . Geoff Parr
#5 PostAuthor: ZedHead » Sun Feb 08, 2015 8:27 pm
Z1parR
#6 PostAuthor: Z1parR » Sun Feb 08, 2015 8:34 pm
Good to see you're back with us Dave :up
It is still Dave isn't it after your rather delicate removal operation :wink:
0172 . Geoff Parr
#7 PostAuthor: zed1015 » Sun Feb 08, 2015 8:55 pm
APE bronze guides are good.
The early Kwak bronze guides were made of inferior alloys which is why they wore out quick.
#8 PostAuthor: ZedHead » Sun Feb 08, 2015 10:12 pm
Z1parR wrote:Good to see you're back with us Dave :up
Thanks Geoff, just goes to prove you don't know what is around the corner.
As far as i know i am still Dave :D
sprint
#9 PostAuthor: sprint » Mon Feb 09, 2015 4:15 pm
ZedHead wrote:http://www.saisei-europe.com/Shop/Products/c/engine/p/valve-guides
I note that APE guides are claimed to sit lower in the head for use with high lift cams:
APE guides are precision machined with the bores finished to size.
They are designed to fit lower in the head to clear high lift cams, and use APE seals or factory OEM seals. Sold in sets of 8
Does that mean they are shorter and therefore, have less support for the valves?
Also the ends of the guides don't look like they will like being drifted in?
http://www.saisei-europe.com/Shop/Produ ... lve-guides
Anybody had any direct experience of the APE guides?
sprint
#10 PostAuthor: sprint » Mon Feb 09, 2015 5:12 pm
Z1parR wrote:Those in the link i bought from zpower , they didn't come with circlips as i found out .
Thanks for the replies.
With respect to reaming after fitting, can you ream the cast iron guides by hand?
#11 PostAuthor: zed1015 » Mon Feb 09, 2015 5:39 pm
The APE guides are only slightly shorter on the cam side so do not have less support for the valve and there is no difference between these and any other guide as regards to fitment and drifting.
The APE guides are actually better that the OEM guides as they use a shoulder rather than a circlip to set their height in the head.
With the circlip it is possible for the guide to be pressed too far into the head by an inexperienced or heavy handed mechanic.
I have fitted hundreds of APE guides amongst others.
You may still need to ream and hone the guides despite what they claim.
#12 PostAuthor: zed1015 » Mon Feb 09, 2015 5:45 pm
YES.
sprint
#13 PostAuthor: sprint » Tue Feb 10, 2015 9:34 am
zed1015 wrote:
YES.
Thanks.
Do you use the same 7.0 mm reamer for the cast iron guides as you do for the Phos/Bronze ones?
Which reamer is best to use, straight or twisted flutes or does it not matter?
#14 PostAuthor: zed1015 » Tue Feb 10, 2015 6:01 pm
sprint wrote:
zed1015 wrote:
YES.
Thanks.
I use twisted flute reamers as they are more accurate and have used the same reamers for both bronze and cast iron.
When using the reamer only rotate it in the direction of cut or you can blunt it.
You will need a guide hone to finish to size after reaming.
sprint
#15 PostAuthor: sprint » Tue Feb 10, 2015 11:56 pm
zed1015 wrote:
sprint wrote:
zed1015 wrote:
YES.
Thanks.
Thanks for the reply. Is the correct reamer with the cast iron guides 7.00mm?
Have not heard the need to then hone the guide afterwards, is it necessary?
