What coil rating for Dyna S
Garn 1
#1 PostAuthor: Garn 1 » Thu Feb 26, 2015 3:25 am
I'm wondering, what is the optimum coil rating for a Kawaski Z1 fitted with DynaS?.
I seem to remember that DynaS recommends coils to be 3 ohm or less.
I think standard Z1 coils are 4 ohm across the primary windings.
I have access to a pair of 3 or 4 ohm coils.
Any thoughts on the topic appreciated.
RegardZ.
Is Vic There
#2 PostAuthor: Is Vic There » Thu Feb 26, 2015 5:36 am
I got in a mess with all this!
In the end I emailed Dyna and they told me to use Green ones (3ohm) in conjunction with the Dyna S system, I originally bought grey ones and then black ones, managed to change the black to the green so all good :D
Hobbo
International Rep
yo
#3 PostAuthor: Hobbo » Thu Feb 26, 2015 7:08 am
3 Ohms Green Dyna
phil
International Rep
#4 PostAuthor: zed1015 » Thu Feb 26, 2015 7:56 am
3ohms minimum resisistance with the the Dyna 'S'.
You can run higher but not lower.
#5 PostAuthor: Pigford » Thu Feb 26, 2015 10:01 am
Do NOT run less than 3 ohms with DYNA S.
I used 2.2 ohms (grey) dyna coils on my Harris :roll: and one of them cracked/melted after 50 miles :cry: so I fitted 3 ohms and no prbs since, so it have to put it down to the wrong coil rating.
2.2 ohms are okay with DYNA 2000 :wink:
