Sidestand for a J
Sidestand for a J
#1 PostAuthor: Al » Sun Mar 29, 2015 12:26 pm
I need a longer sidestand for the J.
Perhaps the Euro J stand is longer (the one with the dog leg in it) or possibly an 1100R one.
What have you got?
Mine is 11 inches bolt centre to toe tip.
tlc
#2 PostAuthor: tlc » Sun Mar 29, 2015 1:16 pm
My measurements of Euro J and Unitrak show they are the same at 11"
#3 PostAuthor: Al » Sun Mar 29, 2015 1:38 pm
Thanks Chris i remember you looking at this before.
Did you get as far as measuring an 1100R one or are they the same at 11 inch.
jphaynes669
side stand.
#4 PostAuthor: jphaynes669 » Sun Mar 29, 2015 7:02 pm
Hello Al, Had a similar issue after raising the back end of my 1000j by 40mm, soon found out I needed a longer stand. All my research was fruitless...nothing! Worked out that it needed to be 330 long. So I cut it just below the peg for the spring, fabricated a piece of tube ( bottle jack handle I think :lol: ), lined it all up and welded it, little bit of work with a flap disc, couple of coats of grey primer and paint and job done....and you can hardly notice
the joints.. Give it a go! :wink:
Jeff.H
tlc
#5 PostAuthor: tlc » Sun Mar 29, 2015 7:36 pm
zorded wrote:Thanks Chris i remember you looking at this before.
Al.
I'm not sure if my 1100R stand is actually the correct item. I had a UK J frame as you know which used the 3 spring version. The 1100R frame is the same as my Euro J but I have fitted a Unitrak stand which whilst it is the same length is cranked in such a way that it fits nicely around my rearsets.
#6 PostAuthor: Al » Sun Mar 29, 2015 9:34 pm
Hello Al, Had a similar issue after raising the back end of my 1000j by 40mm, soon found out I needed a longer stand. All my research was fruitless...nothing! Worked out that it needed to be 330 long. So I cut it just below the peg for the spring, fabricated a piece of tube ( bottle jack handle I think Laughing ), lined it all up and welded it, little bit of work with a flap disc, couple of coats of grey primer and paint and job done....and you can hardly notice
the joints.. Give it a go! Wink
Thanks JP i may end up having to do that but its a slippery slope that way and before you know it you're cutting bits from the frame. :D
Chris yours looks like an 1100R one but here is an original as far as i know.
Not a great picture, the bike was doing about 50 and the camera about thirty metres away
#7 PostAuthor: Ginger Bear » Mon Mar 30, 2015 6:47 am
Al,
Have you considered this sort of thing?
http://japan.webike.net/products/1522797.html
http://japan.webike.net/products/20992523.html
Possibly Dave at Saisei could source you one, or you could consider re-engineering yours in a similar fashion. :wink:
#8 PostAuthor: Al » Mon Mar 30, 2015 9:34 pm
Thanks Steve very neat and tidy that.
Not seen those before but did have something similar on my trials bike.
Taffus
#9 PostAuthor: Taffus » Mon Mar 30, 2015 9:37 pm
I have an R side stand here if you want to try it.....I will need it in the future though :roll:
#10 PostAuthor: Al » Mon Mar 30, 2015 9:47 pm
Thanks Mark i only need it for nine days.
1 in April
2 in May
2 in June
4 in July
and 2 in October
You can have it back in between if you want.
P.S. Litre R or 1.1? is it longer than 11 inch??
Taffus
#11 PostAuthor: Taffus » Mon Mar 30, 2015 9:53 pm
came of fthat R frame...you know the one that has become the never ending money pit of ideas! :lol:
#12 PostAuthor: Al » Mon Mar 30, 2015 9:59 pm
Oh yes that one!
Hey its only money.
big green bus
#13 PostAuthor: big green bus » Wed Apr 01, 2015 4:17 pm
I will have a look tomorrow Al and see if I have anything
#14 PostAuthor: Al » Wed Apr 01, 2015 4:59 pm
Thanks Steve i look forward to hearing.
Only needs to fit and hold it up, nothing fancy.
#15 PostAuthor: Ginger Bear » Thu Apr 09, 2015 7:08 pm
Al,
I've just been 'rooting about' in the shed & found what I think is a Unitrak stand, which appears to be a good half inch longer than your's. :crnk
If you PM me an address I'll get it off to you asap.
