Z1000 LTD rough running- help please
ianz1000ltd
#1 PostAuthor: ianz1000ltd » Wed Jul 01, 2015 11:13 am
Hello,
Just to say, I am not that good a mechanic but I am trying to learn, so I may write things here that you may think are draft so please tell me I am grateful of the help.
I got the bike and since I have had it is ale=ways ran rough, lumpy, back fires etc. So I changed the plugs, caps, leads and coils. I have taken the carbs apart and cleaned them, and checked the jets, the float heights, the diagrams and it all looks good. BUt it is still the same. Then I checked the inlet rubbers- all OK. Now this is where I am getting confused- I put the vacuum gauges accross the carbs and turned over the engine and originally I only had a vacuum on No1, nothing on the others. So I assumed that there must be an issue with the carbs 2,3 and 4 not getting a vacuum , a leak or something- is that right?
Anyway so I thought, well No1 was ok, so I will take items off No1 and swop with No4 and see if it makes a difference. I swopped the diagramm, and the bowl, it made no difference at all. In fact nowwhen I turn it over I get no vacuum on anything.
I have ordered a compression tester, but when I block the inlet port off with a rubber glove, it will pop it, so I guess the engine is sucking. It does this on all cylinders. Also when I turn it over I do get compression through the plug holes.
I am completely confused now, and I realy dont know what to do. If anyone has any ideas that I can try I would be really happy. I just want to get it done so I can go out on it.
Thanks for reading,
Ian
#2 PostAuthor: z1bman » Wed Jul 01, 2015 11:47 am
check the compression & make sure there are no pin holes in the diaphragm rubbers ?
ianz1000ltd
#3 PostAuthor: ianz1000ltd » Wed Jul 01, 2015 12:15 pm
I am pretty sure the diagramms are ok, because when i push the sliders up and block the air way they stay up intill the pressure is released, but I will check ompression, when the tester arrives- thanks
Farmer
#4 PostAuthor: Farmer » Wed Jul 01, 2015 12:42 pm
Take the carb to engine rubber off of number 4 and check mating face to see if its wet, if it is its leaking, replace all 4.
1981 KZ1000 K1 LTD
Farm Boy with an O Level in Metalwork and not much else.
Everything in Sussex is a She, Except Tom Cat and She`s a He.
ianz1000ltd
#5 PostAuthor: ianz1000ltd » Wed Jul 01, 2015 12:49 pm
Farmer,
I have taken them off and checked and resealed them, it is still the same.
thanks for your thoughts
PAULJAC47
#6 PostAuthor: PAULJAC47 » Wed Jul 01, 2015 3:34 pm
Check out this site look down to where it says syschronise carbs,learnt lots of this site ,very good,have had similar probs with these cv type carbs meself.
Paul J
http://members.dslextreme.com/users/bikecliff/
Farmer
#7 PostAuthor: Farmer » Wed Jul 01, 2015 4:58 pm
What are the o rings like on the plugs where the pilot jets are also o rings on float needle seat ?.
1981 KZ1000 K1 LTD
ianz1000ltd
#8 PostAuthor: ianz1000ltd » Wed Jul 01, 2015 6:01 pm
I havent checked them, I will look tomorrow. would that cause me the problems do you think?
Are they the bits you get in the carb refurb kits?
thanks for your help.
Ian
Farmer
#9 PostAuthor: Farmer » Wed Jul 01, 2015 8:44 pm
I was told by Andy at NRP carbs that they are always overlooked, he's got them in stock. :D
1981 KZ1000 K1 LTD
