Top Idler
- steve bowdler
Top Idler
Are the Liska/Ape top idler gear assemblies on the Z1000 a1 one unit or can the bushings and needle roller bearing replaceable and if so where can the parts be purchased from ? Thanks
- Ginger Bear
Steve,
All the usual suspects should be able to help you;
www.saisei-europe.com/Shop/Products/SearchValue/ape .. Dave has 'em in stock.
www.debben.co.uk
www.pitstopperformance.com
www.z1enterprises.com
www.debben.co.uk
The APE and LISKA stuff comes apart with an allen key and the bearing is available separately from liska etc or just get them from simply bearings.
Here -
http://simplybearings.co.uk/shop/p92295 ... _info.html
Here -
- steve bowdler
