zthou a1
john
zthou a1
#1 PostAuthor: john » Sat Jan 23, 2016 11:20 pm
Hi lads
Anyone know by any chance if the front triple trees and swinging arm from thou A1 would fit onto a Z1900 b frame,
mine has gsxr running gear and l want to make it look more standard , l know that the thou was upgraded to disc brake at the back .thank you
Kind regards
John
#2 PostAuthor: Ginger Bear » Sun Jan 24, 2016 7:18 am
I've not actually done what you want to, but I'd have thought it would all go straight in. Headrace bearings are the same for the Z1b & Z1000 & the swinging are pivot bolt were the same diameter.
#3 PostAuthor: zed1015 » Sun Jan 24, 2016 10:25 am
Yes! straight fit.
john
zthouA1
#4 PostAuthor: john » Mon Jan 25, 2016 8:58 pm
Hi Lads
Great, Thanks very much.
Kind regards
John
