Little red switch on L/H switch gear - Z1000J ???
#1 PostAuthor: Pigford » Thu Feb 18, 2016 8:28 pm
Been asked before, but fooked if I can remember what its for - don't seem to do anything on my bike :??
That little one on the top right?
#2 PostAuthor: z1bman » Thu Feb 18, 2016 8:47 pm
side stand cut out over-ride switch
#3 PostAuthor: Pigford » Thu Feb 18, 2016 9:55 pm
Thanx :lol:
I've disconnected mine now - and whilst doing that, noticed that only the black wires were linked to the loom = the brown & pink (?) were not - thats why it didn;t work.
tlc
#4 PostAuthor: tlc » Fri Feb 19, 2016 7:26 am
'Tis a hazard switch on mine.
Handy for filtering on Belgiun motorways.
mikey
#5 PostAuthor: mikey » Fri Feb 19, 2016 11:30 pm
Hazard warning lights switch on my
Ltd 1000
#6 PostAuthor: z1bman » Fri Feb 19, 2016 11:45 pm
hazard switch was only fitted to us bikes. uk bikes had a side stand override switch & if you press the switch it allows you to put the bike onto the side stand without the engine cutting out
KeithZ1R
#7 PostAuthor: KeithZ1R » Sat Feb 20, 2016 4:05 pm
Tis a hazard switch Piggy.
However with some surgery and a double pole relay you can adapt it to switch the lights like wot I have, as the CSR being American had them on continuosly which made starting the dam thing problematic
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#8 PostAuthor: Pigford » Sat Feb 20, 2016 4:41 pm
Mine is a sprung switch - not 0n/off clicky?
Its disconnected now, anyhow thanx :wink:
tlc
#9 PostAuthor: tlc » Sat Feb 20, 2016 4:45 pm
z1bman wrote:hazard switch was only fitted to us bikes. uk bikes had a side stand override switch & if you press the switch it allows you to put the bike onto the side stand without the engine cutting out
Not so. Mine is a general European model.
#10 PostAuthor: Pigford » Sat Feb 20, 2016 4:51 pm
My bike would start only with side stand UP - but would continue running if you put it down. It appeared to only cut the power to starter solenoid - not ignition (sparks).
But it only had the 2 x Black wires connected, not the other x2.
#11 PostAuthor: z1bman » Sat Feb 20, 2016 6:53 pm
sprung type switch is for the side stand
PAULJAC47
#12 PostAuthor: PAULJAC47 » Sat Feb 20, 2016 6:58 pm
Yep did that on my j....
King of Kings
#13 PostAuthor: King of Kings » Sat Feb 20, 2016 7:20 pm
Plastic camchain self destruct button! :twisted:
