Where do Yu Getem ~ Gearbox bearings
Garn 1
#1 PostAuthor: Garn 1 » Mon Mar 28, 2016 5:00 pm
Thought I remembered seeing those two bearings somewhere?
Drive shaft bearing and Sprocket Bearing (cluster/ Layshaft).
Couldn't find them at ZPower or Z1Ent?
RegardZ.
Hinckley
#2 PostAuthor: Hinckley » Mon Mar 28, 2016 6:07 pm
Debbens do good quality ones.
RGH
#3 PostAuthor: RGH » Mon Mar 28, 2016 9:07 pm
Garn go to a good bearing supplier, common as
Output - BL305
Drive - 5305NB
#4 PostAuthor: z1bman » Mon Mar 28, 2016 9:22 pm
Garn 1
#5 PostAuthor: Garn 1 » Wed Mar 30, 2016 3:41 am
Thanks Guys,
Managed to pick up the bearing I was really after. It was the thinner ball bearing on the output shaft. Original Read NSK BL305N.
Replacement was NACHI 6305-2NSE9NR. [Aust $28]
I had to remove the fibre dust covers To allow oil to penetrate, also it came with a full circle retainer ring.
RegardZ
