1979 MK 2 ignition CDI.... Plug gap 30 or 40 Thou ?????
johny brando
Thanks to good info received on here on the Forum, I'm just about to run new BR8EiX Iridium plugs in my 900 which I'm running MK2 Ignition on & there appears to be some confusion within my 2 Clymer manuals...... one say's 30 thou plug gap & the other says 40-44 thou ????? anyone have a genuine MK 2 shop manual to hand ? It'a std UK spec 1979 CDI package & like i said gunna now use Iridum Plugs...they appear to be generically factory gapped @ 30 thou but if thats wrong .....I'll have very carefully re-gap them ....as they look a bit delicate compared to normal plugs ! Cheers.
johny brando
Re: 1979 MK 2 ignition CDI.... Plug gap 30 or 40 Thou ?????
johny brando wrote:Thanks to good info received on here on the Forum, I'm just about to run new BR8EiX Iridium plugs in my 900 which I'm running MK2 Ignition on & there appears to be some confusion within my 2 Clymer manuals...... one say's 30 thou plug gap & the other says 40-44 thou ????? anyone have a genuine MK 2 shop manual to hand ? It'a std UK spec 1979 CDI package & like i said gunna now use Iridum Plugs...they appear to be generically factory gapped @ 30 thou but if thats wrong .....I'll have very carefully re-gap them ....as they look a bit delicate compared to normal plugs ! Cheers.
THANK YOU very much guy's appreciate all the replies !!!! 30 Thou it is then .........yeh 320 might be a Tad over kill !
