Carbs for 1105cc
Carbs for 1105cc
After toying with selling the zed I rode it to see the old man today and it was so flawless and fun to ride that I came to my senses and decided I would throw some money at it instead. Anyway, it has the original carbs on it that tend to flood so they could do with some attention. The motor is 1105cc, can anyone recommend a suitable set of carbs for 'reasonable' mpg that might be better suited? It is an ST with Harris exhaust and pod filters.
1979 Z1000ST
The original 28's are plenty good enough for your spec motor so I'd treat them to a new set of float needles and seats then reset the float heights.
That should cure the flooding and save a bundle of cash.
Maybe even give them a complete refresh with new keyster/nrp internals to tighten up the fueling.
If it's running fine otherwise why go through all the hassle of fitting other carbs that you may never get set right.
Better the devil you know.
Users browsing this forum: Google [Bot] and 65 guests
