Cams
King of Kings
Cams
#1 PostAuthor: King of Kings » Fri Aug 19, 2016 11:02 pm
Can the camshafts stay in situ when removing the cylinder head??
#2 PostAuthor: chrisu » Sat Aug 20, 2016 5:54 am
Nope
You need to remove cams to get the cam chain off
#3 PostAuthor: Pigford » Sat Aug 20, 2016 7:48 am
Or.............. you could cut the chain - and refit with a replacement "rivet" type chain :wink:
Re: Cams
#4 PostAuthor: zed1015 » Sat Aug 20, 2016 11:36 am
King of Kings wrote:Can the camshafts stay in situ when removing the cylinder head??
No and you also must not refit both cams to the head once off as you risk bending valves.
Users browsing this forum: Bing [Bot] and 86 guests
