SHAFT UNIT
ted1r
SHAFT UNIT
#1 PostAuthor: ted1r » Mon Nov 28, 2016 3:04 pm
Can anyone tell me if the rumours are true that the bevel gear unit from a Mk2 shaft will fit STD 1000 cases?
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
#2 PostAuthor: zed1015 » Mon Nov 28, 2016 6:14 pm
Bevel unit will only fit the MK2 type square cam cover motors cases.
Inner cover is a different shape bolt pattern towards the rear of the motor so won't fit the earlier cases up to around 78/79.
ted1r
post
#3 PostAuthor: ted1r » Tue Nov 29, 2016 1:09 pm
Thanks Rob
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
