Engine sprocket removal Z1000R2
Stugill
#1 PostAuthor: Stugill » Wed Dec 28, 2016 7:06 pm
I was keen today ( and well wrapped up ) and started to remove the bits and pieces from the bottom half of the engine to get it on the stand for a spruce up.
All went well until it came to taking off the sprocket, the manual states to use a particular tool that fits into two holes in the sprocket. The sprocket does not have the holes, even if I had the tool!
Any advice on getting the bugger off? or other suggestions?
Stu
Julian_Boolean
#2 PostAuthor: Julian_Boolean » Wed Dec 28, 2016 7:15 pm
With the chain on stamp on the back brake and undo the bolt
Stugill
#3 PostAuthor: Stugill » Wed Dec 28, 2016 7:21 pm
Aaah.
That makes sense, I will give that a go.
Stu
VinnyE
#4 PostAuthor: VinnyE » Wed Dec 28, 2016 8:17 pm
You could also stick the bike in gear and place a 2 by four through the rear wheel and against the swingarm to lock it up.
Do not attempt with a spoked wheel!
#5 PostAuthor: zed1015 » Wed Dec 28, 2016 8:29 pm
Or get (or make) one of these. Also great for holding clutch hubs.
http://www.ebay.co.uk/itm/Sealey-Motorc ... 1044755977
