kawa gpz1100 head wanted
trikerdrew
#1 PostAuthor: trikerdrew » Thu Mar 02, 2017 5:47 pm
anyone got one doing nowt? :lol: :lol:
ta
drew
pluto
Re: kawa gpz1100 head wanted
#2 PostAuthor: pluto » Thu Mar 02, 2017 9:47 pm
I've got 3 of them in various states of repair. B1 complete with cam caps and valves, B2 without caps, B2 gas flowed but has a damaged cap and the odd valve missing, good set of b2 cams as well. Let me know if any or a combination sound suitable.
cheers
Dave
trikerdrew
#3 PostAuthor: trikerdrew » Fri Mar 03, 2017 9:05 pm
Not to sound like a miserable sod but was advised the uni head was the daddy
The B heads need the injection blanking off if my info is correct
Not saying I won't end up with a modded earlier head though.
I am more familiar with the smaller zeds TBH.
drew
#4 PostAuthor: zed1015 » Fri Mar 03, 2017 9:22 pm
trikerdrew wrote:Not to sound like a miserable sod but was advised the uni head was the daddy
drew
If going for a Uni head on the earlier motor be careful of valve to piston clearance especially with hi comp pistons or lumpy cams as the valves are a different angle.
Early Geep and J heads are the same angle as the early lumps but make allowance for the 2 point compression drop unless you are going turbo.
