Unitrack valve gear dims
mattc
#1 PostAuthor: mattc » Tue Mar 14, 2017 3:04 pm
Hi, I am working through a Unitack head measuring everything up vs the manual guidelines for standard range and service limit. Most parts are covered but no free spring length in given for inner/outer valve springs, just squareness. Also no OD or wear limit is provided for the cam followers/buckets/tappets...whatever they are called...
Anybody have some spec numbers they work to?
Matt C
