MK2 v ST headlamp brackets
needaz1100r
#1 PostAuthor: needaz1100r » Mon Mar 20, 2017 9:54 am
Guys,
These look to be the same except for ST ones being chrome and MK2 being black, so part numbers can't help.
Can anyone confirm one way or the other?
Thanks,
Cheers,
Mark.
Redbeard
Re: MK2 v ST headlamp brackets
#2 PostAuthor: Redbeard » Mon Mar 20, 2017 8:05 pm
I only know the fork diameters are different (40mm on the ST to 36mm on the MK2) which may confirm if they'll fit or not? The two bikes don't share much at all unfortunately.
1979 Z1000ST
#3 PostAuthor: z1bman » Mon Mar 20, 2017 10:31 pm
Redbeard wrote:I only know the fork diameters are different (40mm on the ST to 36mm on the MK2) which may confirm if they'll fit or not? The two bikes don't share much at all unfortunately.
as redbeard has said the st forks are 40mm the headlamp brackets are a bigger diameter & taller
needaz1100r
#4 PostAuthor: needaz1100r » Mon Mar 20, 2017 11:04 pm
Great, thanks guys.
Now to find a set of mk2 headlamp brackets....
Cheers,
Mark.
#5 PostAuthor: Al » Mon Mar 20, 2017 11:31 pm
needaz1100r
#6 PostAuthor: needaz1100r » Tue Mar 21, 2017 1:06 am
Yes Al, just like those!
Thank you.
Cheers,
Mark.
nicomkii
#7 PostAuthor: nicomkii » Tue Mar 21, 2017 3:30 am
PM Sent.
Nico
#8 PostAuthor: paul doran » Tue Mar 21, 2017 9:56 pm
I HAVE a used set of MK2 brackets
needaz1100r
#9 PostAuthor: needaz1100r » Wed Mar 22, 2017 8:57 am
I've sent you a PM Paul.
Cheers,
Mark.
Users browsing this forum: No registered users and 77 guests
