1000st chain conversion help needed!
Desperate Stan
#1 PostAuthor: Desperate Stan » Sat Apr 29, 2017 5:11 pm
before putting my crankcases together ,I wanted to make sure the gear change was all working fine ,id already got a mk2 inner sprocket cover and shift shaft.Have also moved the long pin on the shift drum round one place clockwise so when its in neutral it now looks like this.Image
However it wont shift up the gears properly ( fine going down ) when you remove the cover you can see the pawls dont line up squarely with the pins so the higher pin prevents the lower hook from sitting properly under its pin,tried to show this in next photo.Image..unless ive made a mistake? it seems like possibly the gear shift sent is not correct,I asked for a Mk2 but its identical in dimensions to my old st one bar a slightly cut out for the spring,if any one can help it would be really appreciated! cheers
