Z650 Shims
wheelysteve
Z650 Shims
#1 PostAuthor: wheelysteve » Sun May 14, 2017 11:32 pm
What's the process for swapping shims for the under bucket 13mm items as fitted to the Z650 etc.?
Cheers Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Re: Z650 Shims
#2 PostAuthor: kev edwards » Mon May 15, 2017 7:02 am
Take all measurements while cold, remove cams see what sizes are under bucket swap around and replace those needed, replace cams turn engine over a couple of times, recheck, if ok run up to temp, check again next day when cold.
Re: Z650 Shims
#3 PostAuthor: warren3200gt » Mon May 15, 2017 7:51 am
Are you asking what you have to do/get if you want to swop from over bucket (z900) to under bucket (z650)? or as Kev posted how to swop shims on a existing under bucket set up?
wheelysteve
Re: Z650 Shims
#4 PostAuthor: wheelysteve » Mon May 15, 2017 8:12 am
Sorry, I was asking how the shim swapshop works for the smaller under bucket jobs. I need 5 smaller thickness shims for one of my 650's. I've used the shim exchange for the Z1 that Jerry looks after but I know he doesn't do the smaller ones.
The club has a 13mm shim collection available on a swap basis, but who looks after now and how does it work?
Cheers Steve
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
KeithZ1R
Re: Z650 Shims
#5 PostAuthor: KeithZ1R » Mon May 15, 2017 8:32 am
wheelysteve wrote:Sorry, I was asking how the shim swapshop works for the smaller under bucket jobs. I need 5 smaller thickness shims for one of my 650's. I've used the shim exchange for the Z1 that Jerry looks after but I know he doesn't do the smaller ones.
Cheers Steve
contact Steve Parr he has the shims ?I believe
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Re: Z650 Shims
#6 PostAuthor: warren3200gt » Mon May 15, 2017 8:35 am
wheelysteve
Re: Z650 Shims
#7 PostAuthor: wheelysteve » Mon May 15, 2017 2:43 pm
Thanks ......pm sent to Steve
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
