Evening all
can anyone tell me what sze bolt and washer 5 and 6 are on the A1 rear master cylinder it’s one of the missing items from the jigsaw I’m rebuilding and typically is discontinued an neither Z Power nor CMS have any stock
Z1000 A1 rear master cylinder
Re: Z1000 A1 rear master cylinder
I can have a look tomorrow
update: sorry - i thought i had some spare master cylinders but can't find them.
Blackseven
I think I’ve got a spare bolt and washer from a scrap rear master cylinder if you want it. Can’t post until next Tuesday morning though as out of the country. Rob
Rob that would be fantastic i’ll Pm you
Blackseven
Hi, yes, I've found the correct bolt/plug
Not sure if you'll be able to PM me as I've only just registered here and not joined Z1OC yet - I will!
If you want to text me your address on 07710 648800 I'll get it in the post to you tomorrow.
Rob
Rob
Rob
Many thanks for the bolt another problem solved
Regards
Adrian
Regards
Adrian
