z1000a2 clutch spring free length
Guyz ,need info on z1000a2 clutch free spring length,only got tension info in gen manual with no way of testing,also need service limits on friction material...Cheers Paul J
Re: z1000a2 clutch spring free length
My manual shows spring free length as 33.8mm (1.33 inch)
Wear limit 32.3mm (1.27 inch)
Nigel
Nigel
Plates wear limit 3.4mm (0.134 inch)
These are from the Haynes 900&1000 manual, the supplement makes no mention of differences between clutches on both models. Hopefully if I am completely wrong, someone who knows what they are talking about will be along to correct me
Ratty wrote:Plates wear limit 3.4mm (0.134 inch)
Clutch's are the same and the same goes for pretty much the rest of the 903/1015 engines until the MK2.
Thanks Lads thought they were the same just needed to check...
