Set of three re-engineered solid idler sprockets for Z900 - Z1000.
Just the one set surplus to requirements.
They are the ones in the foreground, use original Kawasaki sprocket rings with billet 7075 alloy centres, have new bearings and use the early top bracket which will fit in any Z1 to Z1000 camcover .
£160 posted to UK.
Z1/Z9/Z1000 Solid idler sprocket set. Price drop.
Re: Z1/Z9/Z1000 Solid idler sprocket set. Price drop.
Bump.
Price drop to £160 or swap for new Z9/1000 Dyna 'S' ignition or green 3 ohm dyna coils.
Clever engineering
Rob,
I'll take a set. pm how to pay etc .
Cheers..............Chris
Thanks Chris.
Much appreciated.
PM sent.
Much appreciated.
PM sent.
you have a pm and money..............
Arrived today as promised.
Look very good.
Update: for those with an existing Z1, Z1A, Z1B and Z900 top idler you can reuse your existing rubbers/dowels if they're in good condition.
If you have a later Z1000/Z1R idler then you'll need to source the earlier rubbers as they're just that little bit thicker.
Look very good.
Best to use those APE billet idler blocks.
They only make them to fit the early top idler and never wear out which is why I offered this set with the early one.
Could have provided the later mount though .
I may have one other set spare once I get some more bearings and will give the choice of top mounts.
