Break Calipers
markgb
Break Calipers
#1 PostAuthor: markgb » Sun May 27, 2018 6:44 pm
Hi Guys Just trying to find out what these calipers fit had them a long while but carnt remember what the came off any idea welcome ???? :oops: :oops:
Z1B Happy Days Get the Z out and go for a Blast
Re: Break Calipers
#2 PostAuthor: Garry.L » Sun May 27, 2018 6:47 pm
900A4 and KH triples.
Charlie
Re: Break Calipers
#3 PostAuthor: Charlie » Mon May 28, 2018 12:48 pm
With a pair of em more likely Z650c models unless one of the above has been converted.
markgb
Re: Break Calipers
#4 PostAuthor: markgb » Mon May 28, 2018 6:47 pm
Hi Guys thanks for the info I just brought them as you see them so dont know if they have been messed with so still not sure what they are off
Thanks any way Mark
Re: Break Calipers
#5 PostAuthor: deka » Mon May 28, 2018 7:41 pm
Measure the distance of the mounting holes as they would determine if they are early z or z900a. As they changed after that time
skibs
Re: Break Calipers
#6 PostAuthor: skibs » Mon May 28, 2018 8:03 pm
Charlie wrote:With a pair of em more likely Z650c models unless one of the above has been converted.
+1
Re: Break Calipers
#7 PostAuthor: ADRIAN H » Tue May 29, 2018 1:01 pm
They are Z or Kh callipers from 1976 onwards. Totally different to Z1 calipers. What they are off depends on piston size.
markgb
Re: Break Calipers
#8 PostAuthor: markgb » Tue May 29, 2018 4:29 pm
Hi Guys The hole mounting centers are aprox 72 mm
