Carberetor size
Carberetor size
I have set of 1980 KZ1000 B4 LTD carbs, does anyone know if they are 26 or 28 mm?
Re: Carberetor size
If it's the MK2 square camcover engine it should have vm28's.
To be sure, measure the inside dia of the carb stub that goes in the inlet rubbers.
If it's close to 29mm they are 28's and if they are around 27mm they are 26's.
Re: Carberetor size
These are 26mm and not 28mm, which is what i thought i had.
